Testing and Results
We followed our standard case testing methodology, as detailed in our
previous heatsink and case testing article, and fitted the usual set of hardware into the case, doing our best to hide and tidy cables to ensure as few airflow restrictions as possible. Here's a reminder of the hardware we use.
CPU: Lapped Intel Pentium XE 955 (dual-core, 3.46GHz)
Graphics Card: Sapphire Radeon HD 3850 Ultimate passive cooled
Motherboard: MSI P6N SLI Platinum
RAM: 2 x 512MB Corsair XMS2-667
Hard Drive: 1 x 250GB Western Digital WD2500 7,200RPM
Heatsink: Asus Silent Square Pro
Power Supply: Xilence XP700 700W PSU
While this isn't representative of current ultra high-end hardware, the equipment we use is specifically selected to kick out the maximum amount of heat inside the case. With a passively cooled graphics card and 130W TDP processor at its core to really heat things up and push the case's ability to cope with toasty components to the limit.
In our experience, our CPU stress test is a good way of indicating a case's ability to exhaust hot air and the GPU stress test is a better indicator of a case's intake ability. This is because the GPU is generally further from the exhaust fan and so its operating temperatures rely more on case airflow than exhaust.
Following feedback from the
bit-tech Community, we've changed the way we display case thermal performance. We've removed ambient and case temperatures from our graphs and just left the more important values of GPU and CPU Delta T – the differences between the ambient temperatures and the component's temperature. We feel this provides a much clearer representation of a case's cooling ability where it counts, as well as producing results that are much easier to digest.
      Lian Li PC-P50
      Cooler Master HAF 922
      SilverStone FT01
      Antec Nine Hundred Two (Full Speed)
      Antec Nine Hundred Two (Low Speed)
      Antec Three Hundred (Low Speed)
      Cooler Master ATCS 840
      SilverStone Raven RV02B-W
      Akasa Omega
      Lancool K7 Metal Boned
      NZXT Beta
      Akasa Freedom Xone
  °C (lower is better)
      SilverStone FT01
      Lian Li PC-P50
      Akasa Omega
      SilverStone Raven RV02B-W (high fan speed)
      NZXT Beta
      Akasa Freedom Xone
      SilverStone Raven RV02B-W (low fan speed)
  °Cm (lower is better)
      Antec Nine Hundred Two (full speed)
      Lian Li PC-P50
      Akasa Omega
      NZXT Beta
      SilverStone FT01
      Akasa Freedom Xone
  °C
Read
Cooling Analysis to see what these results mean.
